MargaretB's avatar
MargaretB
Back-up manual tongue jack
My husband is nervous about trailering because he's not mechanically inclined and fears trouble that he can't fix. So the issue of relying on the electric jack came up. I'm wondering if there is such a thing as a manual crank that can be used on a normally electric crank, just in case. Belt and suspenders, that's me. He's concerned about the battery running down and us not being able to hitch up or unhitch.
So is there such a thing as a manual crank for the jack?
  • My electric jack has a little rubber plug on top. Remove the plug and use the included crank handle to raise or lower as needed.
  • All the electric jacks on the market that I've seen have a manual back up. Usually, you just use a socket and ratchet on the nut on top of the jack to perform this task. It's very easy and not complicated at all.
