rockhillmanor
Nov 09, 2015Explorer III
doodleduo wrote:
We can back it in with the truck, but the trailer is coming in at an angle because the driveway has a incline and it's not clearing the garage. If it were coming in level it'd be fine. So I'm hoping there's a way to get it level before entering the garage..?? Idk...maybe have to build a ramp to level the driveway? Not sure how to go about that either :/ A little in over my head here.
Easy fix. Get a trailer dolly.
Has ball on end and handles like a hand cart. YOU can then roll it up to garage and push the handle down to the driveway which will level your PU to fit in under the door.
This one has an 'adjustable' height ball so if you need to move it up more to accommodate the angle of the driveway to make your PU more level.
http://www.etrailer.com/Hitch-Accessories/Rackem/RA20.html
Trailer Dolly by Rack'em Manufacturing.The trailer dolly will allow you to move your heavy trailer around with ease. Great for helping to manuever your trailer into tight spaces like in the garage.
There are less expensive ones for around 50 bucks but from your description of the steep incline to the driveway you might need the extended ball option that is the Rack'em one.
Here's is one for $50.00. Does 'not' have adjustable ball.
http://www.etrailer.com/Hitch-Accessories/MaxxTow/MT70225.html
Call around you might find one to rent at an equipment rental place.
Seems the investment in a dolly is prudent since the HOA is going to be all over you like cheap shirt if you don't! :W
