rockhillmanor wrote:
Truckers have a name for this but I can't recall it. All I know is since I started backing up this way it's a breeze for any situation.
Backing to the driver's side---does NOT have a name that I am aware of.
Backing to the passenger side is referred to as "blind-side". Reason being...as soon as you start to turn, looking out the window shows nothing, the mirror only shows the side of the trailer, looking behind you gets a view of your bunk in the sleeper. In other words, you are "blind" whereas seeing the direction the trailer is going.
Blind-siding is pretty easy with a back window, but backing driver-side is always easier cause you can hang your head out the window and see what your mirrors don't show you.
On a side note....Passing a truck on the left is called the "passing side". Doing so on the right is called "suicide". You think that 25' trailer you are towing has a blind spot----try a 53' trailer and no back window you can look over your shoulder to see out of.
