2012Coleman
Jun 23, 2020Explorer II
Lynnmor wrote:I use "The Scoop" with much success. The trick not mentioned in the video is to have your spotter tell you when the corner of your TT is aligned with the right edge of the space your backing into. Once you start backing, you will be able to see easily. I back my fifth wheel into my driveway from a residential street and don't even run over the grass. The other tip to consider is to start "The Scoop" from as close to the right side of the road as possible. Point the TV towards the site entrance like shown in the video.1320Fastback wrote:
I always try and do the Swoop technique I think they call it when ever possible.
This is the one you are thinking of, works well.
