BarneyS
Jun 26, 2020Nomad
That video is ok but it is only half of the maneuver. Here is how to turn the "scoop" into the "S" maneuver.
EXample: Site is on the left (drivers side). Always try to start with the site on the left.
1. Approach site from right side of road and swing to the left so you are lined up at the beginning of the site on the left side of the road (this is the first part of the S)
2. Slowly drive across the road to the right side (this is the 2nd stage of the S)
3. Turn left and drive across the road to the left side and stop. This should leave you with the truck pointed towards the left side of the road, the trailer pointed toward the right side of the road and angled across the road with the rear of the trailer positioned to enter the site. (this is the 3rd and last stage of the S maneuver).
4. Now, you should be able to start backing up and follow your trailer right into your spot.
After a little practice, you will be able to judge very accurately exactly where to start the S maneuver and where to stop. If your trailer has a long overhang in the rear, be careful of the tail swing when you start the S maneuver if there is a tree or other object
nearby on either side.
If it makes a bit easier to visualize, think of this maneuver as a backwards "S".
I used this for years and could usually position the trailer in the first try.
Hope this helps! :)
Barney
Hope this helps! :)
Barney
