Boomerweps wrote:
Confusion sometimes occur from people working on house electric and mobile electric. House electric BLACK is hot, white is neutral or return, green is ground. Mobile 12vdc RED is hot/positive and black is return/negative/ground.
4x4van wrote:
And to make it even more confusing, many RVs use yellow as positive and white as negative!
I have not worked on all that many campers, but every one I have used white for ground. Now the positive, I have seen black, red, and brown. Yellow is new to me, but I would accept the possibility.
OP, Disconnect the battery, grab your Ohm meter, and check for continuity frame/end of white wire.
Reversed polarity is all that is needed to reverse direction a DC motor runs. And reversed polarity will blow fuse to protect the converter.
