My dealer keeps telling me that I'm expecting too much from my truck and shore power for charging. They've told me both supply up to 2A as does a generator. They want to sell me a solar panel so I ca...
Measure voltage on the converter output terminals. Should be 13.6 or more. At the battery it should be the same. If nkt, use uour jumper cable to rig up a direct line from battery neg th converter neg. If that fixes it, you have a bad negative. If not, try the same with oositive. I found my bad connection on the battery feed negative cable terminal. Tightened that and it worked
