gmw photos wrote:
What I would do is crawl around under there and find every place where metal is rubbing on metal, and lube it with something like CRC with teflon. If there any rollers you can see, lube them too.
Then on every rubber seal, rub copious amounts of baby powder. Then run it in and out and report back.
I've crawled under the slide numerous times. I can't see any rollers. I've used lubes specifically made for slide outs, I've used teflon lube, I've used lube that isn't meant for slide outs. Nothing helps. I've lubed anything and everything including using the little straws to direct the spray lubes into areas normal spray can't get to. Short of tearing the entire underbelly off, I've lubed everywhere I can get to.
The seals and wipers are brand new this Spring. They are soft and supple and are not the problem. The old seals weren't either. I put the slide in and out when all the seals were off and the squeal was still present.
