Hi All, Camped over the weekend and ran into a fellow PUP owner and he brought a BAL leveler to my attention. Doing some research, they seem to be quite popular and helpful. I learned that you don'...
I have one. The camp ground I used had some unlevel spots and it came in handy a few times. If you do get one, after cranking up the low side place one leveling block under the tire. If the tubing of the leveler settles into the ground deep enough and you don't have a block for the tire to come down on you might not be able to pull the leveler out from under the tire. You'll have to crank it back up again.
