69_Avion
Oct 05, 2013Explorer
Possilian wrote:
No pictures of it yet. Been busy unloading the camper. Only posted about it while taking a break to get advice how anyone else handled this out of warranty. I want to upgrade the insulation with reflectex and run some wiring I wanted to do while it is broke. Everything to me is a opportunity! Want to do led lighting under the rails, 12 volt exterior power supply to the outside rear to charge phones. And install a small fan on a switch down there in the basement to increase the air exchange rate for winter camping.
You have the right mind set to tackle this problem. Make all your wanted changes while it is apart. Upgrading your insulation is a great idea.
Is that angle iron bracket part of the mount for the tank? How many gallons is the tank?
