billtex
Oct 05, 2013Explorer II
Well...that sux...but it doesn't look like the tank dropped?
I see the wood/staples pulled away, but the tank seems to be in place.
I have heard of several instances with AF tanks recently...what does Mfg say about using off the truck?
That is a 2013...AF still uses batten type insulation?
I thought everyone switched to foam board by now?
You might consider pulling out all that insulation while you are in there...the reflectix and foam board would be better option...more moisture resistant.
You have the right attitude...time to make lemonade!
Good luck w/repairs,
Bill
Bill
