Possilian's avatar
Possilian
Basement Floor Failure On 2013 Arctic Fox 990
I was getting ready to take a nice short weekend trip loading the camper and filled the water tank. I do this off truck and jacks down till the back step barely clears the ground. Got everything loaded and woke up early this morning to find bottom 8 inches down on the passenger side with a gaping hole exposing aluminum cross members, insulation, and the edge of a water tank. If your thinking that this guy filled the tank with he hose straight into the bung, think again. I lurk on rv.net to know better, not write this sob story. I do fill with the small hose adapter every time. I go running to stop the water when I hear it drip out. And my water here has low pressure anyway. takes about 45 minutes to fill the tanks. Should be perfect right?
Anyhow, out of service for now. Called dealer and they setup a appointment. Said it should take a couple days to get it fixed. I am half wanting to do the repair myself. Being under warranty is the only reason I am going to the dealer. Looking at the brackets AF used makes me wonder how in the heck they could have failed. They look more than sufficient to do the job. It appears the heads broke off the assembly. Also I see lots of insulation and solid looking work in the basement as well. Just my crappy luck showing it's hind end.
  • I am not worried. The dealer is very supporting and I know the north woods reputation. Even that said the more I look at it I cant help but think that it broke on seam of the section of plywood where it stops and rejoins another piece. I really want to know that if only one piece can be used or it is done to help with assembly of the floor since it might be unmanageable to accomplish in one section. Anyone one else had theirs apart?
  • I would definitely suggest that something was not done right at the factory. The way you fill the tank should have no bearing on what you are experiencing. I always fill once the TC is loaded on the truck, but even the way you did it should be ok. Many AF owners use their TCs off the trucks while camping and most have them only on the factory jacks. My guess is somebody forgot to do something right at the factory.
