IdaD wrote:
I wanted to solicit a few opinions on batteries. My 2015 Ram is on it's original set of batteries....a couple of times after running the grid heater on cold mornings the last week or two I've had a click before I turn the key back off and then it has fired up on the second try....Am I at the point I need to replace the batteries?
Maybe so. Had to replace batteries in my '14 last year. I had similar odd behavior on cold starts when using the grid heater. After testing the batteries I found one of them had a dead cell so I was essentially working off one battery.
Be careful when disconnecting. There is a fuse built into the positive battery cable post connector and mine popped somehow during the change. Those post connectors are a dealer only item.
KJ
