Lynnmor
Dec 14, 2014Explorer II
Jaxom wrote:
I had a short aluminum battery box. I trimmed the posts and ruined the battery!
I did the same thing to gain clearance. As you can see, the post is made up of two pieces so you need to cover the saw cut with solder.
I used a pickup side tool box across the tongue and placed the battery box under the lip. That way the thief will need to remove the locked propane bottles for access. The tool box stores blocks and chocks while under way and then stores the hitch parts when camped.
If the OP really needs two batteries, I suggest 6 volt golf cart batteries.
44,071 PostsLatest Activity: Aug 30, 2026
