pjay9
Aug 19, 2014Explorer
Battery 6 or 12 PLAN
I have been doing much reading in many posts about battery selection and amp hrs ...longevity when use with inverter and such. So my question is on my plan.
Plan: Install two batteries in the truck bed forward of the pax side wheel arch. This area is accessible from the TC access door under the refer if I needed to do something while TC is loaded. I would use battery box/es secured to bed with proper ga. wire running along rail of bed to an Anderson battery plug with a pigtail/plug coming out of the TC battery cabinet under the wing so it is all within the bed rails out of harms way.
Andeson Plug example
So the questions are: Ideas to mount batteries? Ideas to have a connection/plug under TC bat box? Other ways to do the connection? Other ways to achieve the goal of more battery power.
I have not decided if it will be 6 or 12, but will be AMG regardless. There will be solar and inverter, eventually. YES I have been reading on both of these too.
So have at it, PLS and THX! :>)
