westend
Apr 09, 2016Explorer
Huntindog wrote:This is good advice.
I don't usually recommend AGM batteries. Yes they have some advantages but I just don't think it justifies the higher price. But this situation cries out for AGMs. No box needed, no corrosion and no work/expense making a custom box. That is what I would do.
Except for an old, cheap Swede like me. :B Actually, I also had some cosmetic reasons for tackling the job (battery box is not hidden).
Since I don't own a rotational molding plant, I had to use materials other than plastic (the best material). I made the box with wood and then lined it with FRP (Fiber Reinforced Plastic). I made the top, a removable piece, the same way and gasketed it to seal any gases inside. Plastic tubing was used for a vent. A nice chrome vent fitting was installed on the exterior.
All of this is not trivial and here is where Hunting Dog's advice becomes reinforced--AGM's don't require a box. You can buy a double battery polyethylene box, hardware, vent tubing, and a vent fitting for a bit less than $100. Or, you can buy AGM's hook them up, tie them down, and be done.
