harold1946
Sep 15, 2015Explorer
Vulcan Rider wrote:harold1946 wrote:
An internal battery short or one in the cables will send voltage to the charger.
What ??
It is a good idea to have a fuse in the charger line but you are doing a TERRIBLE job of explaining why.
Unless the first failure is internal to the charger, it's pretty hard to have the external voltage be higher than what the charger is producing......and thus have current going back INTO the charger.
Voltage is not the important part amps are.
I'll attempt to explain it clear enough so you will understand.
It is wise to always include a suitable fuse in every connection from the battery bank to an appliance. The fuse is there to protect against short circuits and for overload protection. If at any time the current flowing through the fuse exceeds the rated value of the fuse, it will cut off the power supply. Without a fuse a short circuit can cause a fire or even cause an explosion since the huge currents involved release vast amounts of stored energy
A power inverter/charger is no different than any other appliance - a fuse should be inserted into the positive cable from the battery bank, (as close as possible to the battery bank) to the inverter/ charger.
The sizing of the fuse is critical and some inverter/charger manuals have it specified.
First you implied it couldn't happen. Then said my post was a pointless troll. Then said you would no longer participate.
Now I will ask again; how long and how much current does it take to damage a battery or inverter/charger?
Why is there a need for clarification if it can't happen.
You are learning, (quite slowly) but you are learning. I haven't given up on you yet.
44,057 PostsLatest Activity: Mar 12, 2026
