Boon_Docker
Jun 28, 2017Explorer III
RV17 wrote:
As per usual I am here to ask for assistance:
So currently I have a 30amp outlet in my garage and my Camper stays plugged in at all times. Also, when I do go out I have it plugged in at the site at all times. BTW I have a two battery set up that came with the trailer. Seeing as how I don't boondock I am likely to just store one and be rid of it. But I don't want the corrosion to jump to the other battery if the cause is a power issue. Or ruin my batteries. So...
1. I have read some people say this may be the cause of my corrosion? Or could it just be some water getting in there?
2. Should I disconnect my battery when on house power?
a. In order to do this do I remove all wires, just the ground, just power??? Or just unhook the cable that leads to the trailer?
3. Somewhat battery related. Is there a way to get power to my outdoor 120v fridge while travelling?
Thanks!!!!
1. The corrosion will not jump to the other battery.
2. Leave the battery connected, just check once in a while that the water level is OK.
3. You would need to install an inverter to do that.
