rbpru
Jun 29, 2017Explorer II
As suggested, the plating of this terminal is gone with time. The easiest solution is to clean it well, and coat it with grease or other rust inhibiting product.
Corrosion does not jump from battery to battery.
If you disconnect the batteries from the TT, they will self discharge over time.
On or off the charger, standard "flooded" batteries require some degree of monitoring. I cannot speak to the other battery types.
