esox07 wrote:
Hmmm, that sounds/looks like a great setup that would work for me. I cannot add another battery however as suggested in a post above. I have a small 19' trailer and with the propane tank, I do not think there would be room for another battery.
I wonder if the poster prior to this one simply had a low quality cut off switch which resulted in his problems. I would expect that the switches would be designed so that the top part with the switch could withstand the elements if the connectors on the bottom were protected under the battery box lid.
The one in the picture is the one that I used listen to the other guy and get the marine grade one.
