ezrydrsExplorerAug 03, 2015Battery cutoff switchWill the factory panel mounted battery cutoff switch keep the battery from charging when plugged in to shore power?
opnspacesNavigator IIIAug 03, 2015My guess is the yes it will disconnect the charger so the battery will not charge if you are plugged in with the switch off.
Related ContentBattery cutoff switchbattery cutoff switchBattery cutoff switchSwitching toiletsAutimatic Transfer Switch?
