ADK_Camper
Jan 07, 2019Explorer
SoundGuy wrote:ScottyP5947 wrote:
For that reason alone, it seems I should replace the converter. Agreed?
Simply replacing the converter won't change the fact you're charging through cables that are far too long and of insufficient gauge. I simply turned my WFCO off and used a stand alone charger but there's no reason you couldn't do the same with a stand alone charger.
Sound guy is right. An inexpensive manual charger is a good fix for this problem. I have a standard ac outlet in my front storage compartment which enables me to store the charger there and connect it to the battery as needed. With a 10 amp charger I can run my generator about 1 to 1 1/2 hours every other day to keep my battery sufficiently charged. I don't shut off/disconnect the WFCO converter when using the standalone manual charger. The two just run in parallel. This ensures that 12 volt power is never interrupted so on board electronics maintain their settings.
44,066 PostsLatest Activity: Apr 16, 2026
