ADK_Camper
Jan 07, 2019Explorer
So using an automotive charger to charge the two batteries at the same time is no issue? Connected to positive on one battery and negative on the other, of course.
Not quite. If you are using two 12 volt batteries you can connect one to the camper and the other to the charger alternating as required. If you choose to use two 12 volt batteries at the same time they must be connected in parallel. That is connect positive to positive and negative to negative on the batteries and either positive to camper positive and either negative to camper negative. With the batteries connected as above you can connect a stand alone charger by connecting its positive to either battery positive and its negative to either battery negative.
44,066 PostsLatest Activity: Apr 16, 2026
