Boharris's avatar
Boharris
Battery Disconnect at Magnatek Power Center Question
I want to put a battery disconnect switch on my 1998 Thor Tahoe TT, but i want to put it at the breaker panel and not up front at the batteries. Can i actually kill ALL the battery power/charging from the panel? If so, where do i break the connection? I have not pulled the panel out yet, but i wanted the answer so i don't have to stop after pulling it out.
  • I can't say what your trailer has. My Thor built Dutchman has only the breakaway switch attached to the wire before it gets to the converter. I am able to see the wire the whole way, so it was easy for me to figure out.
    Yours? I suspect you will have to do your own digging. :(
