ekirkland's avatar
ekirkland
Battery disconnect switch
I have a new Jayco Whitehawk 27DSRL with TWO batteries and want to install a battery disconnect switch. Is there any reason to get the 4 position switch to enable disconnecting battery 1, battery 2, or both? Or just get the 2 position switch to disconnect both batteries at once?
Next question: Blue Sea or Perko or other; which is better?
Does it matter if you place it in the positive or negative line?
