jy's avatar
jy
battery disconnect switch
I recently changed from a motorhome to a small travel trailer.I have the typical 12 volt battery mounted on the tongue in the plastic box.When in storage I like to unhook the battery.Rather than unstrapping the box,removing the cover and unbolting a cable has anybody found a switch that can be mounted in the side of the box?
    I mounted a Blue Sea m-Series Switch on the side of my battery box years ago, still works just as it should. :B
    Since this pic was taken I've replaced the flooded battery with an AGM and moved the box to the front pass through storage compartment but still use the switch. Highly reliable. :B
  • I have one like this that I put in my RV and it does very well for complete isolation. I think it was around $30.
    Blue Sea Systems marine. This model has connections for two batteries.
    https://www.amazon.com/Blue-Sea-Systems-Selector-Battery/dp/B000FOPE1G
