Buzzcut1
Jan 28, 2017Nomad II
dead battery= no electric jacks even if on 120
your battery(s) are probably toast. Make sure that the replacement is a true deep cycle battery not a car start battery
are you running the fridge on DC? don't, AC or Propane only is the way to go.
Generator. the size will depend on your AC unit. a 2000 watt will only run a 9200 BTU AC anything bigger will need at least 2400 watts up to 3000
you can also get a front hitch reciever then a locking generator tray from torklift which lets you run the generator from the front bumper without having to lug it around
