marksgone's avatar
marksgone
Battery not charging from the truck
Currently in Costa Rica and the house battery (AGM deep cycle) is not getting enough charge to last through the night. I have a 135w solar charging it through the day but only getting a reading of 12.15 from the terminals. With the car running, this does not change. My understanding is that if the truck (F350) was pushing current through to charge the battery then it should read around 13.5 - 14.2. Took it to a battery fellow here and he seems to think the battery is ok, just not getting a full charge. It has enough to work the lights at night but by morning we are in trouble. This has only been a recent development and I drive on some terrible roads. The camper is a Lance 1010.
I need some pretty urgent help as getting RV repair down here is pretty tough and not many places to plug in overnight.
Thanks
  • Just some initial brainstorming here...
    Is there charge voltage at the 7-pin?
    Is there a good ground between truck and camper?
  • If it used to work, could be a fuse. What is the charging system from the truck -- stock? Your install?
