With shore power hooked up:
Measure AC input to converter.....could be fed from a Circuit Breaker or plugged into an outlet
Good AC to converter then measure converter DC output....S/B 13.2V DC MINIMUM
Good DC output then check 'reverse polarity' fuses....could be on front or back of converter...S/B 30A or 40A
Reverse polarity fuses good..then look for an in-line fuse on battery positive cable....30A at least and could be a 'DC Circuit breaker' (small box with 2 studs/pos cable on studs----might have small reset button on side of box)
Good fuses....check battery water levels and specific gravity of each cell
S/B 1.125 (dead battery)
Also check cable connections are clean tight--ESPECIALLY NEG cable ground to frame
Getting battery recharged from dead state is important for battery survival so disconnect battery cables (MARK THEM FIRST) get it hooked up to portable charger and then you can do ALL Voltage testing from converter to battery pos cable with battery disconnected and charging on portable.
