KD4UPL wrote:
Plug in your AC cord and check the voltage at your battery terminals. It should be at least 13.4, maybe a little higher. If it's below that your converter isn't charging.
As for the change over problem, no, it's not normal. The relay that handles that should be build into your converter. It may be sticking or something.
How old of a trailer are we talking about? If you have an older model with a single stage converter now might be a great time to upgrade to a newer 3 stage converter.
Will get out today and check the voltage. I'm guessing I can just disconnect one side of the battery cables and read across the ends of the +/- cables?
This is a 2003 model and has the paralllax 7300 series.
