RoyB wrote:
could you pass along the converter model number... Might give someone on here a clue...
Your frame ground and DC NEGATIVE cable on the converter should not be switched. Only the battery connection should be switched.
Roy Ken
Sorry about leaving out the model Parallax #7300. My fingers were quicker than the brain.
I really like your setup and with the marine switch it looks much cleaner. I have not inside area to locate the switch close to the battery which was why I used the key switch like in your picture. I did place it between the neg lead on the battery to the negative lead that goes to the converter, not to ground.
BUT, I was told, don't remember when, NOT to put it in the pos + lead, only the neg lead.
I guess I got that turned upside down.
Time for a switch re-do or a plain removal might be best as we are full timers now. Not sure when I would ever use it. I only wanted to cut the battery power while it was in dry storage so the batteries did not run down. I had discovered a number of items were still drawing battery power even when everything was thought to be shut down.
On your rig (or others), when would you use the battery disconnect?
Thanks
Randy
