SoundGuy
Apr 18, 2018Explorer
Jethrodean wrote:
Has anybody used that one or any ctek converter.
I have, a CTEK Multi US 7002 ... great charger, does a proper 14.4 volt bulk charge, but it's just a 7 amp charger. If you want a CTEK you'd be far better off with a CTEK Multi US 25000 which is not only a 25 amp charger with temp compensated charging but also has a 25 amp supply mode. Thinking of getting one myself. That said, I'd bet that because you're building your own camper that most would suggest you cut to the chase and install a converter designed for RV use, such as a Progressive Dynamics PD9200 series converter with charge wizard. Might be your best bet. ;)
