SoundGuy
Apr 18, 2018Explorer
Jethrodean wrote:
Got another dumb question if a battery has 210ah if you add another does that double it or keep it at 210ah?
Depends on whether you're talking two 6 volt batteries wired in series or two 12 volt batteries wired in parallel. With two 6 volts the amp rating remains the same while the voltage doubles, with two 12 volts the amp rating doubles while the voltage remains the same.
