jawsthemeswimming428 wrote:
.......Today, our longer cord came and I plugged the trailer in. Within 30 seconds of being plugged in I checked the battery level and it showed 100% full. Am I missing something? It definitely showed empty before that. Any advice would be appreciated.
The indicator just reads voltage. Your converter that supplies 12v power has the capacity to immediately hold the voltage above 13 volts and the indicator reads full. The truth is it still will take 6 to 48 hours to fully charge the battery depending on the model of converter. BTW this is very hard on the battery to run so low. Plug it in minimum 3 days and if you unplug remove a battery cable to prevent discharge.
Print this:
The 12 Volt Side of LifeAnd congrats on the new RV :B
