mbloof wrote:
FWC wrote:
Again, this is all a distraction from the point I was actually making.
The point in the very unlikely circumstance that you need to use your LiFePO4 camper battery in temperatures below -20C, the battery will work just fine, you will be able to fire up the furnace or battery heater and warm up the camper. At that point you can charge your battery, fill your water tank, and do what every you need to do.
Every time there is a discussion of LiFePO4 batteries, there are always a few who say that they are no good if you camp in cold weather (some are now even claiming 'cool weather'). My experience is exactly the opposite, they have worked just fine for me in cold weather. Yes there are limitations on charging, but these are generally easy to overcome, and are not nearly as restrictive as the limitations on your water system.
While it has always appeared that rv.net has more then its share of trolls and internet experts who seemingly always want to argue why something won't work, the reality for me is that for where I live and camp I'd rarely if ever run into temperatures that make charging my LiFePO4 a issue.
Obviously for others their MMV.
- Mark0.
Are you guys trying to inject some reasoning into this subject ? Shame on you .
