naemsmommy
Jul 15, 2015Explorer
Battery questions
I have read a lot of information online, but I'm finding it so confusing, and everyone says something different lol. We don't want anything fancy, we just want to know the best method for charging/using our batteries.
We just bought two new 12V deep cycle batteries. We also have a 70 watt solar panel.
1. Our trailer only has wiring for one battery. What is the best way to hook up the two batteries? I know we shouldn't totally discharge the batteries, so do we just use one until it's at a certain percentage (e.g.50%), then switch to the other one and charge the partially discharged one? Or can we hook both together so it's evenly drawing from both, but still with just a 12v output? And if we do that, how do we charge both at once?
2. We have a smart charger that does 6a/4a/2a. Do we just set it to 6a and then it will automatically switch to 2a when it's charged? The batteries are 115AH, do we need a higher amp smart charger?
3. What's the best way to use the solar panel? Hook it to the battery in use? Or the battery not in use? Or if we somehow wire them together, do we just connect it to one of them?
4. I keep reading that our batteries should be charging while we're towing, but I have no idea how that works? Is there wiring we need to connect from our truck to the battery for that to work?
I'm sure I'm making this much more difficult then it needs to be, but it's just totally confusing and we have had lots of trouble with batteries in the past, so we really want to make sure we do this right this time and don't ruin our batteries.
Thanks!
Thanks!
