RooDude09's avatar
RooDude09
Battery recharge after dry camping trip
What is the best way to recharge the batteries after a weekend trip dry camping? Our trailer is brand new and I put two 6volts on it. They working great on the trip battery meter at 2/3 with nothing running but specific gravity was at about 1200 in most cells which with the four ball type hydrometer would be no balls floating. (I have both types). Tried the small solar panel 1.5watt for two weeks but no change. So I ran the cord and plugged it in and it's been charging for 24 hours but not much change in the SG. Some cells are a little higher than than before others don't show much change. Should I just leave it plugged in for a while till they're fully charged or hook up my 12 volt battery charger?
  • The wfco is probably not going to "recover" the battery bank. Search for a thread on equalization or desulphation.
  • Hi,
    a 1.5 watt solar panel would not even keep up with the self discharge of the six volt batteries.
    You may have caused the cells to become sulfated by waiting so long to properly recharge them.
    What make and model of converter do you have?
