pianotuna
May 13, 2015Nomad III
Hi samhain7,
It will be fine if used lightly.
The smaller the battery bank the higher the wattage should be on the solar panel. The reasonable maximum at 85% state of charge (when the battery starts to taper off charging current) is 12.5 amps per 100 amp-hours of capacity. In your case that translates to 210 watts.
What charge controller have you chosen?
44,028 PostsLatest Activity: Mar 27, 2025
