HMS_Beagle
Feb 18, 2013Explorer II
This is what the inside of the compartment looks like:
There is no structure to the bottom, its just a plastic cover. The tray sits on the sill of the access opening and is thru bolted to the floor at the inboard end. That is how the tanks are mounted as well:
The batteries have to be stuck through the opening sideways and then stood up inside, little bit of a pain but not bad. You would not want to do this with flooded cells, these are Lifeline AGMs:
Both batteries installed. There is actually room in there for 4 of these!:
The batteries are now within a foot or two of the distribution panel which is just above and inboard. I will be installing a Magnum charger/inverter in place of the Parallax ferro resonant charger there. I get to use the aft compartment for something else, and a quick calculation shows I moved the CG of the camper several inches forward by moving 132 lbs from the very back to the very front. Access isn't as good (and you would have to remove the camper from the truck) but with AGM batteries you really only look at them once every few years anyway.
44,072 PostsLatest Activity: Aug 23, 2026
