BCBigfoot106
Feb 22, 2013Explorer
I was thinking of using a battery isolator to seperate the two batteries. To prevent any cross draining between batteries. I was thinking of using a 90 amp isolator. It has 3 posts. One for each battery and one labeled, "Alternator", which would go to the converter? I'm guessing it's a diode based one, like you described. You said they cause a voltage drop?
As far as fuse size, at the battery. Does this need to be slightly larger than the largest draw on the batteries? I think my Happijacs have 2x20amp fuses. So 50 amp fuse?
I'm going to use AGM's and I have a PD 9160 converter. I have some #2 wire to do the runs to the converter.
44,071 PostsLatest Activity: Aug 16, 2026
