RoyB
Jul 05, 2014Explorer III
MORMJS - When we had the older single mode converter/charger that only produced 13.6VDC we would see boiling out of battery fluids pretty regular. I then started checking my batteries every couple of weeks. After installing a smart mode converter/charger system that uses multi-charge modes the boil;ing out of fluids stopped. I still check my battery every couple of weeks out of habit I guess... Your trailer is new enough to have a smart mode converter/charger installed as standard items.
The OP's converter/charger is most likely one of the older single mode DC OUTPUT type converter/charger which will boil out battery fluids over time. Once the battery fluids boil out on you and you do not re-fill right away will cause damage to batteries and will need to be replaced.
Roy Ken
Roy Ken
