GA1dad
Dec 11, 2016Explorer
Battery Tenders
Keep in mind I'm a noob to the diesel world,,,,, So twice now the batteries have run down on my Duramax from lack of use. I'm starting to look for an inexpensive tender that I can mount to the vehi...
austingta wrote:GA1dad wrote:gbopp wrote:
How long does your truck sit between uses?
A couple of weeks and it goes down enough to keep it from starting. It'll roll over a few times, then click/click. Seems like I recall the gauge showing around 10 volts when this happens. If I drive it every few days there is no issue. I should just break down and drive it daily, it gets better mileage than my s-10 4x4. But that little 4 door S-10 is a good commuter.
Thanks for the advise folks!!
There is something wrong for sure. The ECM and other things that use current don't use very much at all. You may have a battery or alternator problem.
Are there other uses that are left connected?
