To extend the life of the exhaust brake, do not operate the vehicle for extended periods of time without activating the brake. On a twice-yearly interval, check and adjust the brake pressure to 10-15 lbs while the engine is at idle.
The hoses, wires, fittings and clamps should be inspected on a regular basis for any deterioration, damage, or leaks.
To prevent the butterfly from sticking due to carbon build up and increase the life of your exhaust brake it should be used frequently. This could simply be switching it on and off a couple times a day.
Technical Service Department at 1-800-887-5030 or 1-604-853-6096, between 8:30am and 4:30pm Pacific Time
