myredracer's avatar
myredracer
Explorer II
Sep 24, 2015
Bearing failure I presume? Warranty?
One day left on a 3 week 2500 mile trip through 4 states. Pulled into our last CG yesterday and while my assistant was inside the office registering us, just for fun I thought I'd see what wheel temps were doing. Lo and behold, one brake drum near the hub was showing about 100F higher than the other 3. I thought maybe I wasn't quite doing it right.
Spent about 10-15 min. cruising around looking for a site and while stopped in front of a site, I checked again and it showed about 30F higher. Must be a bearing failure? Am I okay to limp about 50 miles home from hear at a slow speed off the interstate somewhere?
We took possession of our TT in Apr. of 2014. In Nov. of 2014 after 7 months of ownership, I took it into the dealer for a few warranty repairs. While in, I thought I would get them to pull the drums off and see what things look like. They said all 4 drums were contaminated with grease. After a bit of arguing and a call I made to ALKO, they agreed to rebuild all 4 wheels. Pretty sure it was caused by the dealing pumping grease into the axles during PDI. Maybe the bearing was originally damaged and they just re-used all of them?
So considering the circumstances of being rebuilt at 7 months should a bearing failure be covered under warranty? And I might add "allegedly" but who knows what dealer really did. A bearing shouldn't fail after only 10 months and maybe about 4K total miles this season so far? I wonder if another call to Alko would go anywhere? Have had a lot of trouble with our dealer on other things so I REALLY don't trust them to do much correctly.
Thing is as well, I wouldn't trust the dealer anyway at this point so maybe it is all irrelevant. In a way I'm okay with redoing all 4 wheels and I'd use the best bearings I could find, but it's getting late in the season and pretty soon it will be cold and wet out.
Have read about many a bearing failure and never thought it would happen to us. At least it's not a blowout.
  • 100 degree difference sounds more like a dragging brake to me than a bearing. Would you be able to pull the bearing cap of the suspect wheel and see if there is grease in there? If it looks well greased I would probably drive the 50 miles and get it home then deal with it.
  • Couple of things come to mind. First, what made you 'suspect' something was amiss when you took your rig to the dealer the first time..:h
    ("While in, I thought I would get them to pull the drums off and see what things look like.")
    Why do you suspect a bearing failure?.:h Could you have a brake shoe that's hanging? That would cause the higher temp. Finally, you said your second check showed the wheel at "30F higher". Higher than what? the other wheels or higher than your previous check?...thanks..Dennis
  • have you lifted that wheel off the ground and give it a spin? Could be the brakes on that wheel are just adjusted a little too tight. wheel should spin freely with just a small bit of drag.
