Myredracer:
"Are you replacing all the races and cones and seals? Removing the cones in the drums is a major PITA as there is barely any exposed edge of the cone to catch with a drift to drive it out. I ended up using a piece of 1" EMT and it took a while to work it out. I trust you are using grease that meets Dexter's specs. "
You got that right. What happened to small double notches in the casting so you could get a good bite on removing the race. Poor engineering. I guess cheesy isn't just everything above the axles, it's in them too!
