Thermoguy wrote:
Not in the NE, but the last time I did mine is when I was buying new tires. They did them for $30 each and it took them and extra 5-10 minutes per wheel. I watched them and they showed me how easy it is to do, but probably would have them do it again.
Did they pull the hub, remove the bearings, clean and inspect for wear, install new wheel seals and pack the bearings and hubs in 10 minutes per wheel? Or did they remove the cap jam grease into the hub then reinstall cap.
I guess that's repacking the hub.. Bearings chip and races chip. No amount of grease will help when the failure comes.Check those bearings folks.
