Gdetrailer
Sep 08, 2014Explorer III
apple61275 wrote:
So I am planning on selling my home and living in a 20-23' camper which I have not yet purchased but looking. I live in Upstate NY where it snows alot and can get below zero in winter. I am currently working on a degree so I have to stay here for another 1-1 1/2 years after which I plan to travel with my camper and hopefully settle in a warmer climate. I am planning on insulating the exterior of the trailer, that is go right over the exterior with foam insulation then cover with metal roofing and install small energy efficient windows and door in place of the typical trailer ones. I also plan to build an angled metal roof. I am considering getting a wood stove installed and using a combination of wood and propane for heat-if thats possible. I am considering a compost or incinerator toilet and getting solar panels on roof, also a tankless water heater. I basically want the trailer to be capable of off grid if needed but also be on grid if electric and water are possible-one big issue is where I will park it. Warmer months-April-Oct. I can use campgrounds but Nov.-March my only options may be to rent an outside lot without any water or electric hook-up or rent a space inside a heated barn or other storage. I am trying to set up the trailer to work for both situations. I also need to buy a tow vehicle that I will also use for basic transportation, wondering if a Jeep Grand Cherokee would work? prefer an SUV over a truck but will consider a small size truck if needed especially since I plan to eventually tow quite frequently. Any advice for this novice would be appreciated
Honestly, I am not sure if you are for real or just busting our chops..
Your post sounds like another poster this spring who was planning to have a custom built cargo trailer by a hitech security company with minimalist features for $50K-$100K..
If you really are for real here is a few things to think about as to why your plan is unrealistic..
You mention buying a travel trailer which could be towed by a small SUV then you are going to add insulation to the outside and then add a tin (corrugated?) roof and siding? The weight alone of steel siding and roofing is going to take your trailer into a heavier towing category. Tin is not light nor is it cheap and could easy add 500 lbs or more and cost you $800-$1000!
Not to mention adding furing strips (2x2s or 2x4s) to be able to add insulation will also add considerable weight and expense.. not to mention make your trailer WIDER than legal limits (102" or 8ft 6" is the max allowable width allowed on most public roads without the need for SPECIAL moving permits).
Extra insulation does not come cheap and high R value insulation will easily bust your budget..
You forgot about insulating the floor, typical RVs have R2 or so in the floor you would need to really increase the floor insulation or really be cold..
Have you checked to see if any of your local campgrounds are OPEN during winter? I live in Western PA and ALL the campgrounds CLOSE for the winter. When they close they DO NOT ALLOW ANYONE to live in the closed grounds..
Even IF you found a place that stayed open, most likely they will shut off the water to prevent damaging freezing to the pipes..
Cost, well $300+ per month isn't exactly cheap rent if you have no power, water, sewage in the winter and you have to rely on a generator and perhaps some very expensive solar (you are not exactly in the best place to get a lot of solar power in the winter so you are going to dump tons of money into panels).
Granted, there are folks who do boondock in places like Canada in the winter so it is "possible" that you could make it work but I do not think you are going to find it to be comfortable nor good for your school studies.
I also would highly recommend that you find an apartment or even a MOBILE HOME to rent..
Sorry to burst you bubble.
44,067 PostsLatest Activity: Jun 05, 2026
