bikendan
Apr 21, 2018Explorer
Jim@HiTek wrote:
Warm air rises. If you're seeing moisture from condensation on the bottom of your mattress, you probably just need a vapor barrier under it. It's coming from the ground at night as the air cools outside, it seeps up from underneath the trailer. Also wouldn't hurt to make sure there's no gaps in the bed frame for that warm moist air to infiltrate.
I don't think you're familiar with hybrids beds.
There is no bed frame. The 3" foam mattress lays on top of the opened bunk door.
So there is no gap and that's why there is condensation. There is no air flow.
44,054 PostsLatest Activity: Aug 13, 2015
