KIS_ManExplorerMar 20, 2015Bed clearanceHow much clearance is needed between the front of camper to front of truck bed. If my rubber bumpers touch the front of bed, I only have .5 inch at the top.
pjay9ExplorerMar 20, 2015At the top of "WHAT"?Do you mean at the upper front edge of the bed and the TC?A picture would be so much help!If you mean the top edge of the bed and TC tub front, what is your concern? If it doesn't rub, I would suspect you are good to go.Do you have a heavy rubber bed matt under your TC? It would help with movement issue a little bit. Hope I am on the right track!
Related ContentBed Rail Clearance?Bed rail clearanceTruck Bed ClearanceSofa bed clearanceNose High vs Bed Clearance
