Rbertalotto wrote:
Had the same issue with my Grey Wolf 19RR. I added an outside door and an inside door. Very easily accessible now. Article about conversion on my web site... www.rvbprecision.com
The OP's rig has a king island bed that doesn't butt against the exterior walls of the trailer as does the bed in your GW.
To the OP - regardless of whether you add cabinet doors to the end of the bed platform as I did you can still manually lift the end of the bed platform if you want to store a rather large item that won't fit through the door openings ... and there's no need for gas shocks as you can simply prop the platform in the open position with a piece of wood notched at each end so it doesn't slip out of position - just as shown in my pic. When you're done simply remove the wood prop and lower the platform. :)
